Un-tagged packets - how are VLAN tags applied?
If on a switch you have defined a PVID for a port, a Subnet based VLAN, and a Protocol based VLAN which “rule” is used to apply the VLAN tag to un-tagged packets the port receives.
Does one “rule” take precedence over the others? Are the rules evaluated in some order?
Hi imaohw
VLAN Assignment priority from high to low should be:
Voice VLAN > MAC-based VLAN > Subnet-based VLAN > Protocol-based VLAN > Port-based VLAN > PVID
Best regards,
Zyxel_Derrick
5
Hi imaohw
Best regards,
Zyxel_Derrick
5
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
