NWA1123-ACv2 run multiple SSH commands
I want to run multiple ssh commands with one line on the AP. I tried to separate the commands with a semicolon (;) and && but I keep getting error. You can see the examples down below.
$ configure terminal; wlan-security-profile TestSecurityProfile; mode wpa2; wpa-encrypt aes; wpa-psk 12345678; idle 3600; reauth 1800; group-key 1800;
$ configure terminal&& wlan-security-profile TestSecurityProfile&& mode wpa2&& wpa-encrypt aes&& wpa-psk 12345678&& idle 3600&& reauth 1800&& group-key 1800;
Which way I should follow to do accomplish this task?
Thank you in advance.
Best regards,
Erdem
Hi @Erdem
Would you like to try script? It could also achieve your requirement with a script file. The attachment is an example. Go to MAINTENANCE>File manager>Shell Script, and upload the script file(.zysh). Then Click the "Apply". The security profile will be created successfully.
Please let me know if it helps.
Joslyn
Thank you.
- 438 Beta Program
- 188 Nebula Ideas
- 6.2K Security
- 454 USG FLEX H Series
- 303 Security Ideas
- 81 Switch Ideas
- 278 Service & License
- 435 News and Release
- 91 Security Highlight
