USG 20W upgrade old firmware
I have a Zyxel USG 20W with firmware 3.30(BDR.7) and would like to upgrade it to the latest version. I can only find firmware for the model USG 20W-VPN firmware version 4.35(ABAR.0).
I attempted the upgrade to the device but received and error saying the firmware was incompatible. I am not sure if this is because my device is a different model (note that -VPN is missing in the model number on my device) or because the jump from 3.30 to 4.35 is to big. Or both. I may also be a separate issue altogether.
Any guidance on next best steps would be appreciated.
Hi @Liam_McCallum,
ZyWALL USG 20W doesn’t support firmware 4.35.
Here are firmware 4.35 supported models.
ZyWALL USG Firewall
ZyWALL 110/ ZyWALL 310/ ZyWALL 1100/ USG20-VPN/ USG20W-VPN/ USG40/ USG40W/ USG60/ USG60W/ USG110/ USG210/ USG310/ USG1100/ USG1900/ USG2200 Series
ATP Firewalls
ATP100/ATP200/ATP500/ATP800
Latest USG20W firmware should be BDR.9.
Good morning, sorry if I intrude. I can't backup my zyxel atp800, I can't find it on my atp800. how can I make a full backup of my firewall? Thank you
Hi @Enrico84
Welcome to Zyxel Community
The startup-config.conf file is the configuration file that the Zyxel Device is currently using.
Go to Maintenance > File Manager > Configuration File to copy the startup-config.conf file.
You can refer to the user guide to backup the configuration file.
The information is on page 809 Chapter 40 File Manager Table 352
- 397 Beta Program
- 2.1K Nebula
- 117 Nebula Ideas
- 5.2K Security
- 94 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 69 Switch Ideas
- 921 WirelessLAN
- 35 WLAN Ideas
- 5.9K Consumer Product
- 211 Service & License
- 337 News and Release
- 71 Security Advisories
- 21 Education Center
- 2K FAQ
- 938 Nebula FAQ
- 425 Security FAQ
- 238 Switch FAQ
- 210 WirelessLAN FAQ
- 47 Consumer Product FAQ
- 139 Service & License FAQ
- 72 About Community
- 62 Security Highlight
