SSL VPN client for Linux
secu_guest
secu_guest Posts: 6 image  Freshman Member
edited July 2024 in Security Ideas
Any plans to implement SSL VPN client for Linux?
0 votes
Active · Last Updated
  • Alfonso
    Alfonso Posts: 257 image  Master Member
    edited July 2019
    Hi @secu_guest
    Welcome to the forum.
    I have not tested openconnect (open software to connect to VPS SSL networks) to connect to a zyxel device, but I suppose it could be used ...
    I suggest to try. Do not hesitate to contact me if you want us to do it together.
    Regards
  • DixIT
    DixIT Posts: 1 image  Freshman Member
    Hi @Alfonso,
    I am trying to use openconnect with the ZyXel ssl vpn. I would be glad of your support for this.
    Have you implemented this already ?
    Best regards.
  • txd
    txd Posts: 1 image  Freshman Member
    does anybody succeeded in connecting to a Zyxel SSL VPN?
    I'm trying but obtaining:
    'XML response has no "auth" node
    Failed to obtain WebVPN cookie'
    Am I missing some configuration?
    Thanks,
    Fabio
  • TorstenHess
    TorstenHess Posts: 1 image  Freshman Member
    Would also be interested in a solution.
    Thanks, Torsten
  • Aspen
    Aspen Posts: 1 image  Freshman Member
    Again if I could add my input. I also get the XML response has no "auth" node error. Massive issue that there is no Linux support
