NWA1123-ACv2 Command removed error
I am trying to create 5Ghz wlan radio profile from ssh connection but I keep getting "Command removed due to the platform upgrade." error.
I am running following command
Router> configure terminal
Router(config)# wlan-radio-profile testprofile
Router(config-wlan-radio testprofile)# band 5G
% Command removed due to the platform upgrade. You can look up the new commands in the release note or use TAB or ? to get command help.
How to create 5Ghz wlan radio profile?
Best regards,
Erdem
Hi @Erdem
Please refer to the attachment about how to create 5G radio profile via CLI.
You also can show the CLI detail via the GUI. Click the "CLI", and it will pop out a window to show all the CLI commands when you create/edit every profile.
Hope is helps.
Joslyn
Why don't you use the Web GUI to set the radio? like below screenshot.
Or, any specific setting you're using?
Thank you for the tips. I can manage to create after checking CLI reference.
- 220 Nebula Ideas
- 607 USG FLEX H Series
- 482 News and Release
