Clone ZYWall 110's
I have several Zywall 110's deployed on my distributed corporate network connected around the world by VPNs. I just bought a few more 110's and want to configure them as back-ups (identical swap-out backups) for the firewalls at each location. I thought I could just backup and download the config files from one 110 to another but that does not work. How the heck do you clone these things???
Make sure the firmware version on the Dashboard need to be the same or upload configuration will be failed
Is it that simple? Just make sure the firmware versions are the same and upload the configuration file from the existing/ running 110 to the unprogrammed 110???
or use "Ignore errors and finish applying the configuration file" when applying the config
- 431 Beta Program
- 2.6K Nebula
- 164 Nebula Ideas
- 6K Security
- 364 USG FLEX H Series
- 292 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 6.6K Consumer Product
- 262 Service & License
- 407 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
