Clone ZYWall 110's
Doc_Bill
Doc_Bill Posts: 5 image  Freshman Member
edited April 2021 in Security
I have several Zywall 110's deployed on my distributed corporate network connected around the world by VPNs. I just bought a few more 110's and want to configure them as back-ups (identical swap-out backups) for the firewalls at each location. I thought I could just backup and download the config files from one 110 to another but that does not work. How the heck do you clone these things???
  • Jeremylin
    Jeremylin Posts: 166 image  Master Member
    First Answer First Comment Third Anniversary
    Make sure the firmware version on the Dashboard need to be the same or upload configuration will be failed
  • Doc_Bill
    Is it that simple? Just make sure the firmware versions are the same and upload the configuration file from the existing/ running 110 to the unprogrammed 110???
    PeterUK Posts: 4,264 image  Guru Member
    or use "Ignore errors and finish applying the configuration file" when applying the config
