ZYSH daemon terminates. Restart daemon using telnet?
On a USG310 ( V4.25(AAPJ.1)C0), the ZYSH terminates unexpectedly while editing GEO-groups.
If the firewall is rebooted, ZYSH starts again. However, rebooting is unacceptable due to the interruption of service.
How can I can start the ZYSH daemon from Telnet without rebooting?
I got the same issue on ZyWALL 110 before.
When I try to modify the address group object, the error message pops up "Zysh Daemon is terminated".
Then the local support gave me the date firmware and the issue is resolved.
Hello InterLan,
We suggest to upgrade your device’s FW to the latest one firstly, this issue should had been fixed on this FW version.
The download link will be PM to you.
Charlie0 -
The issue was resolved by an interim release firmware upgrade.
Thank you, Charlie
I'm running into this same issue. USG60, v4.25(AAKY.1). I was able to upload a new conf file with the changes to my Address Groups. Is there an available patch?0
- 441 Beta Program
- 210 Nebula Ideas
- 534 USG FLEX H Series
- 338 Security Ideas
- 51 Wireless Ideas
- 295 Service & License
- 461 News and Release
