USG60W Expert mode
after loggin in (admin + password) to the GUI, i get a blue screen with a turning wheel. When I change the URL "https://.../ext-js/easy_index.html" to "https://.../ext-js/index.html" (without "easy_"), the export mode starts.
Can i define to start default with the expert mode?
Thanks,
RBN
Hi @RBN,
If the GUI is stuck after login Easy Mode GUI.
You can try to use SSH to login device and type these CLI to disable the Easy Mode.
So that you can login with Expert mode GUI.
Router# configure terminal
Router(config)# ezmode deactivate
Router(config)# write
Router(config)# exit
Thank you
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 482 News and Release
