USG60W Expert mode
after loggin in (admin + password) to the GUI, i get a blue screen with a turning wheel. When I change the URL "https://.../ext-js/easy_index.html" to "https://.../ext-js/index.html" (without "easy_"), the export mode starts.
Can i define to start default with the expert mode?
Thanks,
RBN
Hi @RBN,
If the GUI is stuck after login Easy Mode GUI.
You can try to use SSH to login device and type these CLI to disable the Easy Mode.
So that you can login with Expert mode GUI.
Router# configure terminal
Router(config)# ezmode deactivate
Router(config)# write
Router(config)# exit
Thank you
- 431 Beta Program
- 2.6K Nebula
- 164 Nebula Ideas
- 6K Security
- 364 USG FLEX H Series
- 292 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 6.6K Consumer Product
- 262 Service & License
- 407 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
