VPN Session logs
Viceroy
Viceroy Posts: 1 image  Freshman Member
Third Anniversary
edited April 2021 in Security
Hi There,
I would like to create a log to find out times and duration of SSL VPN sessions per user - how might I go about this?
My attempts thus far have not been fruitful...
Tia
  • Zyxel_Jerry
    Zyxel_Jerry Posts: 1,406 image  Zyxel Employee
    Hi @Viceroy
    Welcome to Zyxel community
    Go to Monitor > Log > View Log > select category SSL VPN
    It will show related log of SSL VPN
  • USG_User
    USG_User Posts: 400 image  Master Member
    I'm also interested in, but would prefer a cleared list where only user log-ins and log-outs are listed, means without all of the rest SSL VPN related log entries.
    Further this log is able to list maximum of 200 entries. I've got a lot of different SSL VPN users here. If i.e. 5 users are logging-in/out only once a day, the 200 entries are reached within 20 days (provided only the user login/outs are bening listed). But this doesn't help, if I have to discover who has been used the VPN in last month.
    I've also tried to automatially export such a SSL VPN User list to an attached USB stick. But also in that case a lot of unintentionally data will be saved with.
  • warwickt
    warwickt Posts: 111 image  Ally Member
    5 Answers First Comment Friend Collector Third Anniversary
    Hi Viceroy, to do this you will need to
    1) route the logs to an external host then
    2) on that host strip out (grep ) the L2TP session logs
    its very simple to do
    additional:
    • syslogd
    • newsyslog.conf
    and syslog-ng
    from the USG, use the UI Configuration/Logging/ setting and put in the info for the remote server
    • optionally change the port
    remote server: [freebsd,linux,macos etc]
    • tail /grep the logs as you see fit
    • make sure you trim these logs (newsyslogd) as they get large after a few weeks with a typically busy router
    Optionally:
    • set the USG router settings for that remote server  to only log specific log event (VPN IpSec/IKE and L2TP
    theres info on this forum for this i recall
    we do this for all our installed zyxel usg routers
    hth
    Warwick
    Hong Kong
