VPN Session logs
Hi @Viceroy
Welcome to Zyxel community
Go to Monitor > Log > View Log > select category SSL VPN
It will show related log of SSL VPN
I'm also interested in, but would prefer a cleared list where only user log-ins and log-outs are listed, means without all of the rest SSL VPN related log entries.
Further this log is able to list maximum of 200 entries. I've got a lot of different SSL VPN users here. If i.e. 5 users are logging-in/out only once a day, the 200 entries are reached within 20 days (provided only the user login/outs are bening listed). But this doesn't help, if I have to discover who has been used the VPN in last month.
I've also tried to automatially export such a SSL VPN User list to an attached USB stick. But also in that case a lot of unintentionally data will be saved with.
Hi Viceroy, to do this you will need to
1) route the logs to an external host then
2) on that host strip out (grep ) the L2TP session logs
its very simple to do
additional:
• syslogd
• newsyslog.conf
and syslog-ng
from the USG, use the UI Configuration/Logging/ setting and put in the info for the remote server
• optionally change the port
remote server: [freebsd,linux,macos etc]
• tail /grep the logs as you see fit
• make sure you trim these logs (newsyslogd) as they get large after a few weeks with a typically busy router
Optionally:
• set the USG router settings for that remote server to only log specific log event (VPN IpSec/IKE and L2TP
theres info on this forum for this i recall
we do this for all our installed zyxel usg routers
hth
Warwick
Hong Kong0
- 603 USG FLEX H Series
- 481 News and Release
