ftp bounce attack
The bounce attack occurred when ALG FTP is enabled.NAT works with ALG FTP, and client must set PASV mode.Enable ALG FTP DISABLE ALG FTPPASV ok failACTIVE fail failWhen ftp client select Active mode, client selects an IP and port to transfer data.ZyWALL by default detects bounce attack and drop this packet.Hence, make sure the ftp client is PASV mode.5
Just curious that the log message will display on USG when your local PC which behind USG try to access FTP?
The FTP bounce attack is an exploit of the FTP protocol. Here is more detail.
http://www.securityfocus.com/advisories/174
Yes, the error display, when local user try to connect remote ftp. And the connection does not occur.
I did this rule for all lan ip, and part of PC connect, other part falls with subject error.0 -
- 435 Beta Program
- 176 Nebula Ideas
- 425 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 419 News and Release
- 89 Security Highlight
