Reputation filter blocking Sharepoint
iSpeed
iSpeed Posts: 110  Ally Member
edited April 2021 in Security
Ok had the same issue as others except with sharepoint.com
It was difficult to figure out, as these services are turned on by default.
  • Zyxel_Jerry
    Zyxel_Jerry Posts: 1,359  Zyxel Employee
    Hi @iSpeed
    Yes the current design the function of IP Reputation is enable in default settings,
    For IP reputation block IP address, would you share the IP address list that was blocked to us?
    We will compare with the cloud database and evaluate if we’re going to add them into our signature database.
  • iSpeed
    13.107.136.9 empathicpracticellc.sharepoint.com
  • itxnc
    itxnc Posts: 102  Ally Member
    First Comment Friend Collector Seventh Anniversary
    We've had to disable the Phishing IP Block on our ATPs for now.
  • Zyxel_Jerry
    Hi @itxnc
    Would you share the IP address list that was blocked by the device?
