How to setup routing WAN ports to LAN servers ports.
ECMS1
ECMS1 Posts: 2 image  Freshman Member
edited April 2021 in Security
I know this is a simple question.. I just purchased my USG20W router and trying to learn it. What are the steps to allow certain ports to come in from my WAN to my LAN servers?
    PeterUK Posts: 4,415 image  Guru Member
    In a simple LAN1 to WAN1 by SNAT setup
    You go from network > NAT add
    you want Virtual Server
    Incoming interface = WAN1
    Source IP = can by any
    External IP = make a new object address with address type INTERFACE IP and interface WAN1 and select it for the External IP
    port mapping type = port/ports
    your protocol and external to internal
  • ECMS1
    HELL YEA. THANKS. Peter. :D
