Zywall 1100 - multiple static ip
Hello everybody,
We’ve purchased a Zywall 1100 VPN-Firewall and now try to add our static IPs from the ISP. As described in the manual we added a IP to an Interface and then adding a virtual interface for the next ip and so on.
Our Problem is that there is a limitation to 4 virtual interfaces on one physical interface. Setting up 15 IPs would need 3 WAN Ports.
Is there another way to configure static IPs?
Thanks for your time
Hello Phormsianer,
Just want to confirm one thing first, as your description, in your scenario, only 3 interfaces can be Wan ports, others already been Lan interface?
By default Zywall 1100, there are three option interface (ge 6,7,8) which means you can modify option interface to be Wan zone. The Following steps as below.
Option interface ge 6,7,8
Modify ge6 to be Wan zone
Charlie
Hello Charlie,
Thanks for your answer.
I’m aware of the option to change the Zone for an interface. But that won't really fulfill our needs.
What I’m looking for is a way to bind more than 5 static wan IPs to one physical interface.
Why would I do this? Because using 3 physical interface for 15 IPs on a 100mbit connect is a waste of ports and this is only the backup line.
So any further suggestions?
Marc
Usually, I'm use multiple public IPs for NAT to internal servers.
I'm interesting on the application that would like to apply 15 IPs on the interface.
What about using VLAN's?
Yes, NAT port forwarding seems able creating over 10 rules on 1 physical port. (even using different IP address from your WAN side)In my view...the virtual interface just a IP address which able managing your device.That is really waste IP addresses........lol0
So you've got 15 public IP addresses, at 1 ISP with one router?
I assume you've got 3 blocks of 5 IP addresses.
In the example below I use 2 ISP's with both one block of 5 Public IP's, which will only use 2 WAN ports (need to use 2 WAN ports because I've got 2 ISP routers):
Each WAN port has a fixed IP:
WAN1
IP Address: 95.97.143.186
Subnet Mask: 255.255.255.248
Gateway: 95.97.143.185
WAN2
IP Address: 80.127.121.154
Gateway: 80.127.121.153
Because the ISP is giving me a 255.255.255.248 subnet I can use 6 Hosts per subnet (-1 for the Gateway = 5 public IP's per ISP connection)
Under 'Object | Address/Geo IP' I've created a 'HOST' for every single public IP I've got.
WAN_1_186 HOST 95.97.143.186
WAN_1_187 HOST 95.97.143.187
WAN_1_188 HOST 95.97.143.188
WAN_1_189 HOST 95.97.143.189
WAN_1_190 HOST 95.97.143.190
And the same for WAN2
Once you've got all your public IP's configured, you go to NAT, and there you map the public IP to an internal IP.
So in your case, when you've got 3 blocks of 5 with one ISP, you should setup one WAN with the first block. And create a virtual interface for the second and third block. After that you should be able to setup the 15 public IP's as mentioned above.
If your ISP assigned 15 x 1 public IP, I won't have a solution for you ;-)
One physical port only can support 4 virtual interface on my usg.
Just curious that why do you want to create 4 virtual interface on one port, because the virtual interface just a IP address which only able managing your device.
- 588 USG FLEX H Series
- 477 News and Release
