WAC5302D Rebooting
Good evening,
I have a problem with an AP model WAC5302d-s, which when at least 1-2 stations are connected after about 15-30 min the ap restarts automatically.
The AP is managed by controller via a USG-1100 with firmware 4.33 and firmware for the Ap V.5.00. is powered by a GS-1900-48HP switch.
As a precaution, I checked the cabling section, replacing network ports and patches, but the problem persists.
We also changed the PoE energy mode of the eth port of the switch from Consumption to Classification, but the problem persists.
Are there any other tests you need to do? could it be due to a firmware bug?
Regards
Hi @Filippo
Could you help to collect diagnostic of the USG and AP for me when the issue occurs?
MAINTENANCE>Diagnostics>Diagnostic>Collect/Collect on AP
Please provide the diagnostics for me via private message. We will analyze the logs to find out the root cause.
Thanks.
Joslyn
from zyxel italia support, they suggest me to update the usg firmware to 4.35.
At the moment the AP is disconnected from the system, as soon as I get back on the spot I will do all the tests including diagnostics.
I will let you know
Thank you.
?I have upgraded the firmware of the usg to version 4.35 patch 2 as suggested by the support of zyxel italia, the version of the wi.fi controller and the ap has also been updated, the problem seems to be solved
thank you.
- 438 Beta Program
- 188 Nebula Ideas
- 6.2K Security
- 454 USG FLEX H Series
- 303 Security Ideas
- 81 Switch Ideas
- 278 Service & License
- 435 News and Release
- 91 Security Highlight
