Small change to DDNS
PeterUK
PeterUK Posts: 4,264 image  Guru Member
edited April 2021 in Security
Would it be possible when adding a DDNS for IP address for Custom to link to the address objects list?
thanks
  • Zyxel_Charlie
    Zyxel_Charlie Posts: 1,034 image  Zyxel Employee
    Hello PeterUK,
    Just want to confirm your request,
    do you want to add the domain name which is link to object list?
    Example:
    If yes, this feature will be supported on FW: 4.30.
    Charlie
    edited October 2017
    Where its got custom IP to have a drop box of address objects including IP interface.
  • CHS
    CHS Posts: 181 image  Master Member
    Why you need additional drop box of interface IP address object...
    If you select interface, then will use this interface IP address directly.
    But thats not the interface IP I need and if its e.g 192.168.1.1 it be the effective wrong IP for like no-ip to get.
  • Zyxel_Charlie
    Hello PeterUK,
    The request "adding drop box of address objects on custom IP", I would like to move your request to the ideas section.
    Charlie
    edited October 2017
    Hello PeterUK,
    Charlie
    Yes thats what I would like so that the sending interface is not the IP I need to send in custom IP that can change on another interface that can't be the sender.
    My thanks for adding this to ideas section
