Where I can find manual how to setup Amazon Web services
@Foma
You may have look the attached document as your reference. On this scenario, the role of USG is applying the configuration which is generated by AWS Console.
There are some limitation on AWS spec., please read it first.
Limitation on AWS
Charlie0 -
Im having zywall 310, running 4.33(AAAB.0). I was following the above guide trying to get access from my AWS instances to my local network, created the config file, removed the date added, configure terminal, at the beginning, write at the end. Applied the script but nothing in the Packet Floe Explore, select the “Static Dynamic Route” table section. I even went further and added aws's neighbour ip address and AS number from the config file still nothing i cant ping anything on my local network from my aws instances or the other way around
Hi @mpopov
Welcome to Zyxel community
At your previous mentioned “Applied the script but nothing in the Packet Floe Explore” , it seem the script failed to upload to ZyWALL 310.
Can you private message the script for check further ?
- 588 USG FLEX H Series
- 476 News and Release
