USG 110 - wan priority
Hi there ! Im using Zyxel USG 110. I would know how can I prioritize a wan link , for example put the wan 2 in priority 1, not the wan 1. Because I have 2 internet links (WAN1 with a VPN & with ppp interface) and wan2 which is with my highest bandwidth. But my LAN goes out to the lowest bandwidth link!!
I tried to modify the wan zone , but I cant remove wan2 links. I wanted to add another rule with Lan outgoing to my wan2 link with a new zone with my wan2 exclusively. But it doesnt work.
An easy way to do that ?
Also, if I add this routing rule, the LAN outgoing will go threw wan2 link or Im wrong ?
Thanks for your help
WAN 1 with VPN and ppp interface? What kind of VPN service (L2TP, site to site IPSec, or SSL VPN) is implemented in your WAN 1? If the your purpose is mainly to have the manipulated load balancing between WAN 1 and WAN 2, you can implement WAN trunk for such requirement.
Moreover, to force your specific to go through the vpn tunnel, you can add a policy route to further identify the route
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 482 News and Release
