Change default pop3 and smtp port for email security
Hi @Pikappa
Welcome to Zyxel community
Here is the command to specify the port
Router(config)# utm-manager anti-spam defaultport <1..65535>
Check defaultport by the command
Router(config)# show utm-manager anti-spam defaultport
Since you have the same post in another thread, we will remove the duplicated one.
In the manual there is a section that reports:
"The Zyxel Device’s email security feature checks SMTP (TCP port 25) and POP3 (TCP port 110) emails by default. You can also specify custom SMTP and POP3 ports for the Zyxel Device to check. " but there is no further instruction (!?)
So .. Where/how can I specify the ports ?
Hi @Pikappa
Hi @Frabre,
Please use "Router(config)# no utm-manager anti-spam defaultport <1..65535>" to delete.
If you don't know which port is incorrect, please use "Router(config)# show utm-manager anti-spam defaultport" to check.
Zyxel Melen0
- 220 Nebula Ideas
- 608 USG FLEX H Series
- 299 Service & License
- 482 News and Release
