Configure a USG110 to use PPPoE (DSL)?
Is it possible to set up a direct PPPoE connection with a modem in bridged mode? I see it as some level of fallback option, not sure if it can really handle being the full authentication device and connection.
Basically, have a DSL modem that can be placed in bridged mode to assign an IP and use the USG110 as the gateway, but I need to make sure it will be able to handle that before I proceed.
Hi @BMS
Do you just need to use the USG110 to dial up the PPPoE connection? (the modem running in bridge mode)
If so, you just need to :
- Configure your ISP connection information in "Configuration" --> "Object" --> "ISP Account", there are some pre-configured profiles and you can just edit one of them
- Configure the PPP interface in "Configuration" --> "Network" --> "Interface" --> "PPP" to build up a ppp interface, the configured ISP connection profile in step 1 will be applied in the PPP interface profile settings
- Click on "Connect" button in the PPP setting page to trigger the device to dial up to the ISP
5
Hi @BMS
5
- 601 USG FLEX H Series
- 480 News and Release
