Zywall 310 - communication between IPSEC VPN clients
Hello everybody,
I try to setup communication between IPSEC VPN clients on Zywall 310. Clients can connect and ping LAN interface, but can’t ping each other.
My setup:
Zywall 310
WAN
192.168.31.135
255.255.255.0
LAN
172.16.0.1
255.255.0.0
Users are using Shrew VPN client to connect. Client’s IPs are static from subnet 172.17.0.0/16.
Policy Generation Level: required
Remote Network Resources: 172.16.0.0/16, 172.17.0.0/16
Can anybody help me to find right configuration?
Thank you.
I also got the same problem when using ZyWALL IPSec VPN client.
Use mode config on both ZyWALL and ZyWALL IPSec VPN client but clients cannot ping each other.0 -
Change the configuration as following, and check it again.
LAN1: 172.16.0.0/16
VPN Connection:
Scenario: Server role
Local Policy: 172.16.0.0/15
VPN client Address: 172.16.100.X/24
- 603 USG FLEX H Series
- 481 News and Release
