ZyWall USG20 Firmware Update
Justas
Justas Posts: 1  Freshman Member
edited April 2021 in Security
Hi, can i use firmware (3.30(BDQ.9)C0) for ZyWALL USG 20 if now is 3.00(BDQ.4) ?
    PeterUK Posts: 4,049  Guru Member
    Yes be sure to save your config in case you need to reset.
  • Zyxel_Jerry
    Zyxel_Jerry Posts: 1,376  Guru Member
    Hi  @Justas
    Here is the firmware link of ZyWALL USG20
    ftp://ftp.zyxel.com/ZyWALL_USG_20/firmware/
    Upgrade to 3.30(BDQ.0)C0 first , then upgrade to 3.30(BDQ.9)C0
    And please backup configuration before upgrade the firmware.
    Since you have the same post in another thread, we will remove the duplicated one.
    Zyxel
    Untitled Image
