Speedtest from router
electsystech
I'd like to see the ability to do an internet speed test from the router for diagnostics.
3
Yes, we do have the plan regarding to this enhancement. Thanks for your suggestion.
How about a UDP speed test?
Hi there, did this ever get implemented? I’d love to run a speed test directly on my router to help troubleshoot network bottlenecks. Thanks! Currently using a usg20-VPN0
I'm also interested.
I use a AX7501-B0
This is now 3 years later. What's the plan for this enhancement?
I have discovered a command related to speed test on the USG60W.
You can try using this command on other models as well, as mentioned in the article.
https://community.zyxel.com/en/discussion/comment/16058#Comment_160580 -
So … still no options in this case ?
- 3K Nebula
- 232 Nebula Ideas
- 6.7K Security
- 683 USG FLEX H Series
- 362 Security Ideas
- 56 Wireless Ideas
- 7.1K Consumer Product
- 309 Service & License
- 504 News and Release
- 96 Security Advisories
- 5.1K FAQ
- 89 About Community
- 111 Security Highlight
