Firmware Update
I installed the new firmware and got this message "Wrong CLI command, device timeout or device logout" it flashed quick and stated to the don't turn off computer still updating. It flashes quick so I had to keep taking picture to see what it read because the other screen covers it up right away. After 5 min I hit F5 and it tried to restatrt but would't so I closed browser and re opened it and it seems to have loaded the new firmware. My old Firmware was "V4.35(AAKZ.2) / 2019 and the new firmware is now "V4.35(AAKZ.3) / 2020. Do I need to be concerned about the message. It says firmware is up to date. Thanks
Hi @Snowtoy
After upgrade to the latest firmware, does the message pop out again?
Can you private your configuration for check further?
No the message does not pop up again. How would I send you my config?
- 441 Beta Program
- 210 Nebula Ideas
- 538 USG FLEX H Series
- 340 Security Ideas
- 51 Wireless Ideas
- 295 Service & License
