IKEv2-Connector
I'm trying to establish a VPN connection via IKEv2 and the authentication should make an AD.
In the USG an AAAServer ( ad ) was created.
Within Auth.method: created "auth_ad_administrators " and method: ad stored .
Within the ( ad ) also users are shown during "test", which works.
Within User/Group: ad-user_adminstrators, also here "testuser" is found during the test.
If I now in the configuration: VPN_Gateway
under Phase1, extended_Authenticaion_Protocol
Server_Mode: auth_ad_administrators
Allow_User: select ad-user_administrstrators.
Always comes AUTH fail!
what else am I doing wrong?
On the windows_server, I see no entry in the "event log".
Have you experienced this / how did you implement this
Solution:
Radius established.
Divert all connectors to the radius.
Done.
IKEv2 on the client now logs on to usg110, which forwards the authorization to the radius, which then releases the network access.
Have a nice weekend
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 482 News and Release
