ZyWALL USG 100 Plus and TLS 1.2
k1601
k1601 Posts: 11 image  Freshman Member
edited April 2021 in Security
Hello!
Is it possible to enable TLS 1.2 on the ZyWALL USG 100 Plus?
I know that it is old device and support closed but maybe exist some variants? (like this for the old USG 300 https://businessforum.zyxel.com/discussion/3477/zywall-usg-300-and-tls-1-2)
Most popular browsers stop supporting TLS 1.0 and 1.1 and use modern browsers for control will be impossible.
Thanks!
  • Zyxel_Jerry
    Zyxel_Jerry Posts: 1,401 image  Zyxel Employee
    Hi @k1601
    ZyWALL USG100 Plus does not support TLS1.2.
    If TLS1.2 is needed, you can consider USG110 which supports TLS1.2
    Here is the information of USG110
    https://www.zyxel.com/tw/zh/products_services/Unified-Security-Gateway-USG110-210-310/introduction
  • k1601
    Hello!
    But I have a problem with update my USG-100Plus.
    When I try to update firmware from 3.30(AACV.7)ITS-WK28-r72114 to the "USG 100-PLUS 330 AACV v3.30P9 (WK48)" process stopped.
    On the console displays:
    [Update Filesystem]
            Updating Filesystem
            [/util/zld_fsextract]
    and rotated slash.
    At this stage (slash rotated) very long time (one week) without any others actions. I was able to interrupt it only by turning off the power, after which the device does not boot with the message on the console:
    FLASH: AMD 16M
    BootModule Version: V1.17 | 12/01/2011 05:20:17
    DRAM: Size = 256 Mbytes
    Kernel Version: V2.6.25.4 | 2016-07-14 09:27:45
    ZLD Version: V3.30(AACV.7)ITS-WK28-r72114 | 2016-07-14 10:14:06
    Press any key to enter debug mode within 1 seconds.
    BM cmd line: console=ttyS0,115200 root=/dev/ram init=zyinit "-r /dev/sda", address: 0x100000
    Uncompressing Linux...done.
    Start to check file system...
    /dev/sda2: 26/17352 files (3.8% non-contiguous), 16993/69296 blocks
    /dev/sda3: 152/41120 files (28.9% non-contiguous), 45664/163841 blocks
    Done
    mount: wrong fs type, bad option, bad superblock on /dev/loop0,
           missing codepage or other error
           In some cases useful info is found in syslog - try
           dmesg | tail  or so
    Kernel panic - not syncing: Attempted to kill init!
    I can restore the device via flashed the database only (firmware restore didn't help). After the restoration the device works normally with the all my old settings.
    I tried hardware reset device before upgrade - it didn't affect. What could be the reason and how can I flash the device?
  • shani
    shani Posts: 4
    same problem here. The wk48 version was applied and it was stuck, had to recover. Anyone able to apply the firmware?
  • Zyxel_Kevin
    Zyxel_Kevin Posts: 975 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Sales Associate 100 Answers 500 Comments
    Hi @shani ,
    Greeting Forum, Please kindly try to hardware reset.
    Also we recommend that you replace your appliance due to security issues and performance concerns as USG100 has been end of service for a while.
    Thank you
  • shani
    shani Posts: 4
    Thanks @Zyxel_Kevin, however after reset, it still didn't work, so i put the previous firmware and applied the settings to get back to where i was,
    Welcome to ZyWALL USG100-PLUS
    Username: admin
    Password:
    Router> configure[resd] Sending signal to zyshd_wd
    Configuration has been restored to system default.
    Username:
    Terminate All Processes: OK
    kill_process_and_umountfs() returns -6
    Restarting system.
    FLASH: AMD 16M
    Kernel Version: V2.4.27 | 2015-01-08 20:52:20
    ZLD Version: V3.30(AACV.7) | 2015-01-14 21:15:46
    /dev/sda2: 31/17352 files (0.0% non-contiguous), 61557/69296 blocks
    /dev/sda3: 116/41120 files (4.3% non-contiguous), 22984/163841 blocks
    Done
    INIT: version 2.86 booting
    Initializing Debug Account Authentication Seed (DAAS)... done.
    Setting the System Clock using the Hardware Clock as reference...System Clock set. Local time: Wed May 24 09:32:23 DGMT 2023
    INIT: Entering runlevel: 3
    Starting zylog daemon: zylogd zylog starts.
    Starting syslog-ng.
    Starting ZLD Wrapper Daemon....
    Starting uam daemon.
    Starting App. Patrol Daemon.
    Starting myzyxel daemon.
    Starting periodic command scheduler: cron.
    Start ZyWALL system daemon....
    Check signature package
    Got LINK_CHANGE
    Port [2] Copper is up --> Group [2] is up
    ...............................................Applying system configuration file, please wait...
    no startup-config.conf file, Applying system-default.conf
    Use system default configuration file (system-default.conf)
    ZyWALL system is configured successfully with system-default.conf
    Username: admin
    Password:
    Router> FLASH: AMD 16M
    Enter Debug Mode
    USG100-PLUS> atkz –f –l 192.168.1.1
    ERROR
    ERROR
    ERROR
    USG100-PLUS> atcd 0
    ERROR
    USG100-PLUS> atkz -f -l 192.168.1.1
    -f -l 192.168.1.1
    OK
    USG100-PLUS> atgof
    Booting...
    Now booting kernel in FLASH
    BM cmd line: console=ttyS0,115200 root=/dev/ram init=zyinit "-f -l 192.168.1.1 -r /dev/sda", address: 0x100000
    intird start:0000000084136000 size:00000000000781A3
    vmlinux start:0000000084006000 size:000000000012FD5C
    mount: fs type sysfs not supported by kernel
    Connect a computer to port 6 and FTP to 192.168.1.1 to upload the new file.
    Firmware received ...
    Done
    Building ...
    [Update Filesystem]
    Updating Code
    -/rw/compress.img bad CRC d05c62e9 (should be d6eda5d8)
    (may instead be incorrect password) //rw/compress.img bad CRC d05c62e9 (should be d6eda5d8)
    (may instead be incorrect password) /rw/compress.img bad CRC d05c62e9 (should be d6eda5d8)
    (may instead be incorrect password) \
