ZyWALL 310 GUI dead after SSL Import
Gizmagis
Gizmagis Posts: 5 image  Freshman Member
edited April 2021 in Security
I have imported wildcard certificate to ZyWALL (256 - 2048) and it was accepted (pfx with password). However, when selecting this certificate for usage, the GUI dies completely and the ZyWALL is inaccessible from any browser, machine...
The only way is to login via SSH and revert the certificate back to default.
Any idea?
  • Zyxel_Jerry
    Zyxel_Jerry Posts: 1,406 image  Zyxel Employee
    Hi @Gizmagis
    Welcome to Zyxel community
    Import certificate files are limited.
    You cannot include multiple certificates (server, intermediate, root) in the same file.
    Here is a similar forum discussion for your reference.
    https://businessforum.zyxel.com/discussion/comment/1985#Comment_1985
  • Gizmagis
    Good morning Jerry,
    thank you for your reply but could you be so kind and help me out a little more? For 2 weeks I am playing "ping pong email" with one of the ZyXEL agent about the certificates and all I am getting is unfriendly and unhelpful reply every single time.
    I am being told that 3rd party SSL are not supported on USG if they have not been signed on USG and that if I have one, I have to import PFX into Trusted Certificates not My Certificates. But under Trusted Certificates PFX cannot be imported. Anyway, I have read the other thread but not quite sure what to do with it; Could you please help me out with steps what to do and what to import where for my SSL being recognized and used for HTTPS interface, VPN, etc.
    I have: PFX bundle with Private key and 3 separate files (crt): cert, intermediate and root.
    Thank you so much!
  • Zyxel_Jerry
    Hi @Gizmagis
    If you're using linux utility tools.
    Here is the example command line to separate files:
    Export private key and certificate only(public key)
    private key:
    openssl pkcs12 -in test.pfx -nocerts -out test.pem -nodes
    public key:
    openssl pkcs12 -in test.pfx -nokeys -out test.crt
    To verify private key/public key match in certificate
    Example:
    openssl x509 -noout -modulus -in test.crt | openssl md5
    (stdin)= XXXX53825f966c1a533fc9a11XXXXXXX
    openssl rsa -noout -modulus -in test.pem | openssl md5
    The stdin value should be the same.
