L2PT - USG60
I have a problem with using L2TP...If I try connect directly to WAN port (pc->usg60->local LAN), l2tp correctly make connection. But, if i try used local ISP ( ISP router board->usg60->local LAN) l2pt connection say:
Connect by ISP:
Successful L2PT by directly connect:
I dont know, where is problem..
Thank you
David
Connect by ISP:
Thank you
David
Hello DavidPr,
According the pictures you shared,
it displays Phase 2 local policy mismatch, so make sure the VPN policy on both site (ISP’s router and USG)are the same first.
Charlie0 -
SOLVED:
Problem was on the side ISP, IPsec dont like dstnat 1:1 for public IP.0
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
