When policy route is used for failover IP-Sec tunnels die. Why?
I am a lucky guy! I have two fiber hookups to the internet. One is 500M/bit, te second 100M/bit. I would like to use the 500 as the main pipe and the 100 as a failover.
Therefor I have created two policy routes where if the 500 (Ge3) fials, the 100 (Ge2) takes over. In theory this works fine as I also changed the trunk to spill-over (user configured). When I activate the policy routes my IP-Sec VPN tunnels die however.
I have been looking if I can find a way to leave the tunnels up and running but cannot find a way.
What can be the problem?
Hi @JeroenSoree
Regarding to the topology you deployed, it’s our suggestion that you can implement VTI to achieve the purpose.
VTI VPN Tunnel Interface is used to configure IPSec-based VPNs between site-to-site devices.
VTI is similar to other physical interfaces so that policy route, static route and trunk can be applied when the tunnel is activated.
Here is the FAQ of how to setup IPSec site-to-site VPN by using VTI on the USG .
- 3K Nebula
- 232 Nebula Ideas
- 6.7K Security
- 683 USG FLEX H Series
- 362 Security Ideas
- 56 Wireless Ideas
- 7.1K Consumer Product
- 309 Service & License
- 504 News and Release
- 96 Security Advisories
- 5.1K FAQ
- 89 About Community
- 111 Security Highlight
