ZyWALL USG 300 and TLS 1.2
  • Zyxel_Jerry
    Zyxel_Jerry Posts: 1,376  Guru Member
    Hi @StouAdmin
    Welcome to Zyxel community
    I’ll sent you the firmware in private message.
    Zyxel
    Untitled Image
  • marekpavlicek
    marekpavlicek Posts: 1  Freshman Member
    I'm still using device USG300 with official fw 3.30(AQE.7). But now I have problem with TLS1.2, which is not yet supported. I found that exist firmware 3.30(AQE.7)ITS-WK48-r74988 for TLS 1.2 support. Can you help me, where I can get this one?
    Thank you very much for your help.
    Marek Pavlicek
  • Zyxel_Jerry
    Hi @marekpavlicek
    Zyxel
    Untitled Image
  • Fallenstar911
    Fallenstar911 Posts: 1  Freshman Member
    Hello
    I use USG 300 devices, and have come across TLS. I found on the forum what can be solved with firmware 3.30 (AQE.7) ITS-WK48-r74988, tell me how to get it?
  • Zyxel_Jerry
    Hi @Fallenstar911
    Zyxel
    Untitled Image
  • Mikkoy
    Mikkoy Posts: 1  Freshman Member
    Hi, is it possible to receive that firmware too for the USG300?
    Im also looking to enable tls1.2 but the firmware i'm using is
    ZyXEL Communications Corp.
    model           : ZyWALL USG 300
    firmware version: 3.30(AQE.7)
    BM version      : 1.12
    build date      : 2015-01-13 16:31:42
  • Zyxel_Charlie
    Zyxel_Charlie Posts: 1,034  Zyxel Employee
  • Hello Zyxel, it's possible to receive the firmware for an USG100
    model           : ZyWALL USG 100
    firmware version: 3.30(AQQ.7)
    BM version      : 1.13
    build date      : 2015-01-13 16:30:24
    Impossible to enable TLS 1.2...
    Thanks! :)
  • mMontana
    mMontana Posts: 1,434  Guru Member
    You should look for WK48 firmware. And enable strong cyphers.
  • alexey
    alexey Posts: 188  Master Member
    @Zyxel_Emily
    Hi, is it possible to receive that firmware too for the USG1000?
    We use 3.30(AQV.7)ITS-WK28-r72114.
