USG40 cofinguration
2»
  • damianodec
    damianodec Posts: 42 image  Freshman Member
    hi @PeterUK
    thank you fo replay, and sorry for the late reply, we are very busy with the covid- 19 rules.
    I am in stan-by with the configuration, what do I do?
    your directions don't work, am I doing something wrong?
    thank you
    PeterUK Posts: 4,264 image  Guru Member
    edited March 2020
    Are you sure your PC is connected to the DMZ port?
    Can you connect to 192.168.1.237.?
    your ISP router LAN is 192.168.1.0/24?
    can you try with your PC set to DHCP
  • damianodec
  • damianodec
    Router has DHCP ON from 192.168.1.170 to 190
    if I set normal configuration (router to switch without USG40) and set my pc with dhcp it returns ipconfig 192.168.1.175 255.255.255.0
    edited March 2020
    Remove GTW IP on WAN1
    I don't see how you can go wrong with a simple bridge
  • damianodec
    hi @PeterUK ,
    my ISP support told me that ISP aethra router has vlan configured inside.
    Vlan 20 for voice traffic and Vlan 30 for data traffic, these VLAN are trunk and tagged.
    could this be the problem?
    this is actual configuration
    What happens if you connect a PC without the switch to the BG7520W router?
    Its not like your PC's at tagged for a VLAN so at the very least the switch untags for the USG40 so it should just work.
  • damianodec
    I'll try it this evening when come back to office.
    Yesterday I'm try this configuration but this also did not work:
