USG 40 - Extension for SSL VPN
we're using a USG 40 to access our office from remote location.
We've set up L2TP connection but it's totally not reliable as almost every time a user reboot it's computer (all Win 10 machine) it doesn't work and it gives error 789.
So I want to switch to SSLVPN as it's more stable and works like a charm but noticed that our USG has only 5 free slots. My question is: is this the right code we have to buy in order to extend SSL VPN capacity to it's maximum?
The license code I've find is this:
LIC-SSL-ZZ0016F
LIC-SSL, SSL VPN License add 10 Tunnels for Unified Security Gateway and VPN Firewall
Is this the right code?
Thank you
Kind regards
Kari
Hi @kaika313
Yes, the License Code to extend 10 SSL VPN user for USG40 is LIC-SSL-ZZ0016F,
Here is the reference of USG40 specification.
https://www.zyxel.com/tw/zh/products_services/Unified-Security-Gateway-USG40-40W-60-60W/comparison
5
Hi @kaika313
5 -
- 435 Beta Program
- 176 Nebula Ideas
- 120 Nebula Status and Incidents
- 433 USG FLEX H Series
- 299 Security Ideas
- 79 Switch Ideas
- 276 Service & License
- 428 News and Release
- 89 Security Highlight
