USG 40 - Extension for SSL VPN
kaika313
kaika313 Posts: 40  Freshman Member
edited April 2021 in Security
we're using a USG 40 to access our office from remote location.
We've set up L2TP connection but it's totally not reliable as almost every time a user reboot it's computer (all Win 10 machine) it doesn't work and it gives error 789.
So I want to switch to SSLVPN as it's more stable and works like a charm but noticed that our USG has only 5 free slots. My question is: is this the right code we have to buy in order to extend SSL VPN capacity to it's maximum?
The license code I've find is this:
LIC-SSL-ZZ0016F
LIC-SSL, SSL VPN License add 10 Tunnels for Unified Security Gateway and VPN Firewall
Is this the right code?
Thank you
Kind regards
Kari
