ZyWALL USG 300 and TLS 1.2
  • Zyxel_Jerry
    Zyxel_Jerry Posts: 1,406 image  Zyxel Employee
    Hi @StouAdmin
    Welcome to Zyxel community
    I’ll sent you the firmware in private message.
  • marekpavlicek
    marekpavlicek Posts: 1 image  Freshman Member
    I'm still using device USG300 with official fw 3.30(AQE.7). But now I have problem with TLS1.2, which is not yet supported. I found that exist firmware 3.30(AQE.7)ITS-WK48-r74988 for TLS 1.2 support. Can you help me, where I can get this one?
    Thank you very much for your help.
    Marek Pavlicek
  • Zyxel_Jerry
    Hi @marekpavlicek
  • Fallenstar911
    Fallenstar911 Posts: 1 image  Freshman Member
    Hello
    I use USG 300 devices, and have come across TLS. I found on the forum what can be solved with firmware 3.30 (AQE.7) ITS-WK48-r74988, tell me how to get it?
  • Zyxel_Jerry
    Hi @Fallenstar911
  • Mikkoy
    Mikkoy Posts: 1 image  Freshman Member
    Hi, is it possible to receive that firmware too for the USG300?
    Im also looking to enable tls1.2 but the firmware i'm using is
    ZyXEL Communications Corp.
    model           : ZyWALL USG 300
    firmware version: 3.30(AQE.7)
    BM version      : 1.12
    build date      : 2015-01-13 16:31:42
  • Zyxel_Charlie
    Zyxel_Charlie Posts: 1,034 image  Zyxel Employee
  • TheIT74
    TheIT74 Posts: 1 image  Freshman Member
    Hello Zyxel, it's possible to receive the firmware for an USG100
    model           : ZyWALL USG 100
    firmware version: 3.30(AQQ.7)
    BM version      : 1.13
    build date      : 2015-01-13 16:30:24
    Impossible to enable TLS 1.2...
    Thanks! :)
  • mMontana
    mMontana Posts: 1,468 image  Guru Member
    You should look for WK48 firmware. And enable strong cyphers.
  • alexey
    alexey Posts: 193 image  Master Member
    First Comment Friend Collector Eighth Anniversary
    @Zyxel_Emily
    Hi, is it possible to receive that firmware too for the USG1000?
    We use 3.30(AQV.7)ITS-WK28-r72114.
