Vpn ipsec IKEv2 how many clients at a time
Good morning, I managed to create an Ipsec Ikev2 client to site vpn and it works well, the only problem I have is that no more than 4/5 users connect at a time. Is it a configuration problem? For access I have configured windows client Win7 / Win10
Hi @carteo
What device model and which firmware are you current using?
Can you describe more detail about the symptom “the only problem I have is that no more than 4/5 users connect at a time.”?
Zyxel
Hi @Jerry thanks for your answer, the model is USG40 with firmware V4.35(AALA.3) and my problem is that i have about 15 users that have to login with ipsec ikev2 but when there are 4+admin the others can't connect, when a user logged logout another users can login. I was wonder if is a bad configuration or other
Hi @carteo
How many tunnel is there on your site?
On USG40, it support 20 concurrent IPsec VPN tunnels.
Go to Monitor > VPN Monitor > IPSec
Can you have a screenshot on this page?
Zyxel
Here is the screenshot, the maximum number of connected users was 10 (9+admin) and just because i configured an ssl vpn so some users can connect with ikev2 and other with ssl. Now i've bought a licenze for 10 tunnel, do you think i solve my problem? When you say that usg40 support 20 concurrent ipsec tunnel you intend without other licenze? Because if it so there's something wrong in my configuration and i don't know where to look.
Thanks for your answer
Hi @carteo
Can you share the configuration of your IPSec VPN settings by using private message?
We can help to check if anything went wrong in your settings.
Zyxel
- 438 Beta Program
- 188 Nebula Ideas
- 6.2K Security
- 454 USG FLEX H Series
- 303 Security Ideas
- 81 Switch Ideas
- 278 Service & License
- 435 News and Release
- 91 Security Highlight
