USG100 Teamviewer traffic blocked
shopy95
shopy95 Posts: 11 image  Freshman Member
edited April 2021 in Security
Hi. Hou I can blocked the teamviewer traffic on USG100? Many thanks.
  • shopy95
    USG100
  • shopy95
    PeterUK Posts: 4,446 image  Guru Member
    Teamviewer uses TCP/UDP port 5939 by default so you could block from like LAN1 to WAN that service.
  • alexey
    alexey Posts: 193 image  Master Member
    First Comment Friend Collector Eighth Anniversary
    Also you can block ip range 185.188.32.0/22 to WAN. This denied all traffic to TW servers.
    In our organisation we used both metods - port & ip range.
