Site-to-Site VPn with USG60 and USG20W with bridge for WLAN and LAN
Hi folks,
i have some trouble with the following site-to-site VPN configuration.
On the central site i use an USG60 with actual firmware.
In the other site there is an USG20W. To use WLAN and LAN1 interfaces there is an bridge between both interfaces. This bridge is working fine and stable.
Now i need an Site-to-Site VPN between the 2 USG. Config is fine and the connection is established. (Both USG say so). From the USG20 site i can use the tunnel and everything works fine.
The Problem is from the USG60 site. There will be no communication to the USG20-Site. I guess it is not an firewall theme because i deactivated both firewalls and problem was still there.
Must there anything be done because of the bridge-configuration? The Bridges uses the IP-Range 192.168.4.0/24 with LAN1 192.168.40.0/24 and WLAN 192.168.41.0/24 in background.
Where is my blindness ?
Christian
Welcome to Zyxel community
What firmware are you current using on both device?
Can you draw your topology with IP address and private message your configuration to us?
Hi @Zyxel_Jerry
the firmware on the USG20W is 3.30(BDR.9)
and on the USG60 is 4.35(AAKY.3) running
The pm is on the way to you.
Christian
- 434 Beta Program
- 2.6K Nebula
- 170 Nebula Ideas
- 116 Nebula Status and Incidents
- 6K Security
- 393 USG FLEX H Series
- 295 Security Ideas
- 1.5K Switch
- 43 Wireless Ideas
- 267 Service & License
- 412 News and Release
- 87 Security Advisories
- 4K FAQ
- 83 Security Highlight
