Rule Order Using the Move Feature
I know this is probably a stupid question, but I am under the Policy Route Tab Under Network - Routing. All I am trying to do is use the Move Feature by highlighting the rule then click Move and type the number for example to move Rule 1 to be rule 2 I put in 2 under Move then click Move and nothing happens. Am I missing something here? Exactly how do move a rule. I done a bunch of googling and have not found a solution. This is the most ridiculous that I can not figure out. Can someone please provide me some guidance on how to adjust the order of my Policy Route rules? Thank you in advance.
Here is the example of settings priority on policy route.
Select the third policy rule and click Move
And enter the number "1" in the blank and press enter.
Then the third rule would change to the first rule in policy route.
5
When you click move and put in number you then press enter on the keyboard.
5 -
Thank you! That worked!
- 603 USG FLEX H Series
- 481 News and Release
