problemi con zyxel gs1900
buongiorno
ho problemi di stabilità di alcuni zyxel gs1900 ,perdono l'indirizzo statico che assegno e tornano in dhcp ?
Welcome to Zyxel Community
The forum support for English, please post in English so that other people who is interested in the same topic will be able to join the discussion.
Good morning I have problems with the stability of the zyxel gs1900, they lose the static protection that I assign and they return to dhcp
Welcome to Zyxel community!
In factory-default setting, GS1900 will get DHCP as management IP when DHCP server is available in the network.
After you set a static management IP for it, you must click "save" button on the top right to write the config into memory so that it would not go back to DHCP after rebooting.
Zyxel_Lucious
good morning, thank you for your reply
Everything he communicated to me has been done several times, but the problem has arisen several times.
I was wondering if it was necessary to update the fw.
It's always better to keep your firmware updated, the latest one is 2.50 for GS1900 series.
The basic idea is the same that remember to click save after configuration change.
Zyxel_Lucious
thanks for the tips
- 220 Nebula Ideas
- 608 USG FLEX H Series
- 299 Service & License
- 482 News and Release
