Connection site to site with peer dynamic
delescja
delescja Posts: 4  Freshman Member
edited April 2021 in Security
I have created a connection site to site but i have a problem.
The vpn is created and activated but I have not access from the other site.
the connection is between HQ and my home. I used usg20 and usg40.
In my Home, the Zyxel is located after the router (ISP). I have a subnet 192.168.0.0/24 in my router and 192.168.16.0/24 in my Zyxel
In VPN Gateway in my Zyxel, I choose wan1 (DHCP 192.168.0.5)
In HQ, there are already VPN's to connect.
I probably forgot to configure a few things but I don't see
Thks for your help
  • delescja
    first, thks for drawing. it's perfect. (which program did you use ?)
    I have not configured any policy route (only those included because I reset it)
    In HQ, in log, I see "no rules DROP" and I see address IP 192.168.16.33 (My PC at home)
    *I would like 2 VPN in different places (14.0/24 and 16.0/24)
    In my Home when I use command Ping 192.168.1.20
    In HQ
    thks for your help
  • Zyxel_Jerry
    Zyxel_Jerry Posts: 1,359  Zyxel Employee
    Hi @delescja
    I do a simple test on our site, if there is no policy route and no security policy blocked the packet, ping should works fine.
    I suspect that there might be some setting is not correctly.
    Can you share your configuration on VPN settings on both device?
  • delescja
    edited March 2020
    Hi @Zyxel_Jerry
    Yes, it's possible. What exactly do you need ?
    Or would you like a connection with Teamviewer ?
  • Zyxel_Jerry
    Hi @delescja
    Can you private message configuration file of both devices for check further?
    The startup-config.conf file is the configuration file that the Zyxel Device is currently using.
    Here is step to download startup-config.conf on the device.
    Go to Maintenance > File Manager > Configuration File > select startup-config.conf > click Download
  • delescja
  • Zyxel_Jerry
    Hi @delescja
    I do not received your private message, can you try to send your configuration file to us again ?
