Group of IP addresses
cpg_juraj
cpg_juraj Posts: 19  Freshman Member
edited April 2021 in Security
Hello. I have a zyxel zywall usg 100 and would like to create a group which would be connected to a rule to block access or terminate the connection. This group would consist of IP addresses which I should be able to edit, thus add or remote public IP address that might be potentially harmful. Thank you.
Best Answers
  • cpg_juraj
    Hello. A wonderful tutorial. Thank you. Just one more clarification. If I want to block incoming traffic from the blocked IP addresses, would I create a rule with the "source" blockaddressgroup?
  • cpg_juraj
    Thank you again for your prompt expertise.
