Group of IP addresses
Hello. I have a zyxel zywall usg 100 and would like to create a group which would be connected to a rule to block access or terminate the connection. This group would consist of IP addresses which I should be able to edit, thus add or remote public IP address that might be potentially harmful. Thank you.
Best Answers
Hi @cpg_juraj
Here is the example to group IP address
Go to Configuration > Object > Address >Address > click Add
Add two IP range into the rule
After added in to the rule, go to Configuration > Object > Address > Address Group > click Add
Select previous IP range to group the member.
Then can select the group IP address as destination in Firewall Rule
5 -
Hi @cpg_juraj
Yes, you can create the rule to block the source IP address.
5
Hi @cpg_juraj
5 -
Hello. A wonderful tutorial. Thank you. Just one more clarification. If I want to block incoming traffic from the blocked IP addresses, would I create a rule with the "source" blockaddressgroup?
Hi @cpg_juraj
5 -
Thank you again for your prompt expertise.
- 384 Beta Program
- 2.1K Nebula
- 116 Nebula Ideas
- 79 Nebula Status and Incidents
- 5.1K Security
- 70 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 70 Switch Ideas
- 907 WirelessLAN
- 34 WLAN Ideas
- 5.9K Consumer Product
- 210 Service & License
- 332 News and Release
- 71 Security Advisories
- 21 Education Center
- 1.9K FAQ
- 884 Nebula FAQ
- 415 Security FAQ
- 226 Switch FAQ
- 198 WirelessLAN FAQ
- 46 Consumer Product FAQ
- 137 Service & License FAQ
- 73 About Community
- 63 Security Highlight
