How to read real time logs
On Zyxel Zywall 35 and Zyxel Zywall 2 and 2+ there is real time logs where we can read it inside the router through web interface.
But on Zyxel USG20 and USG20-VPN router, there is no such option to read the activities logs. Anyone have any idea how does the logs works on Zyxel USG 20 and USG20-VPN ?
Hello josephsw,
Per talked,
if the log messages are over device's capable of storing maximum records, the older logs will be flushed.
Just enable the log of feature which you want to collect on log category to avoid logs missing.
Charlie
5
Hello josephsw,
Per talked,
Charlie
5 -
It seems the maximum log entries on USG20-VPN is 512. Try to send logs to a remote syslog server in case old logs are flushed.0
Yap ! i managed to get log service working in real time. Thousand thanks to Charlie hints.0
- 222 Nebula Ideas
- 616 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
