Creating a New Separate "RYO/user" Zone for specific IKE Tunnels?
Hi fellow avid Zyxel USG users, any clues on the following are most graciously accepted..
Question??:
Would like to add a customised Zone that contains only specific IKEv2 and IKEv1 client-site connections for the purposes of administering very explicit Policy Routes as a "logical Group" - as a name "MY_own_Zone_Tunnel_Group"
Currently one must maintain a bunch of very explicit Policy Route maintained for every IPSEC connection.
Use Example:
I have two Client-Site VPN active connections as and associated IPSEC gateways as
- 01-L2TP-IKEV1_client_connection ... and
- 02_IKEV2_client_connection
I would like to have a user zone called "MY_own_Zone_Tunnel_Group" that contains only these two connections so that I can have a single set of Policy routes for both.
and... Yes these both are currently working 100% ok.
Below are the items in the system zone called TUNNEL on this lab USG40.
Router# show zone TUNNEL No. Type Member =============================================================================== 1 interface tunnel1 2 tunnel 01-L2TP-IKEV1_client_connection 3 tunnel ios-test_L2TP_cert_V1_CONN 4 tunnel 02_IKEV1_client_connection Router#
I'd like to have 2 & 4 in another zone of my choosing called "MY_own_Zone_Tunnel_Group" that I could access as
Such a Policy Route might be: for MY_own_Zone_Tunnel_Group
index: 18 active: yes auto-disable: no description: lab3_L2TP_004_SUBNET_to_LAN1_subnet user: any schedule: none interface: none tunnel: MY_own_Zone_Tunnel_Group <<=============== example! sslvpn: none source: lab3_L2TP_004_SUBNET destination: LAN1_SUBNET DSCP code: any service: any srcport: any nexthop type: Auto nexthop: auto nexthop state: Not support auto destination: no SNAT: none DSCP marking: preserve connectivity-check: no Router#
Status:
Cant get such a configuration when using the cli "zone" command or the WEB UI (User Add+) there doesn't seem to be a way of configuring a user zone that doesn't not contain USG predefined interfaces.
Any clues, comments or alternatives or wisdom ?
Many Thanks
warwick
Hong Kong
Hi @warwickt
Do you mean to create a specific zone and can select each VPN connection into it?
And the zone can be selected in policy route settings?
Hi Zyxel_Jerry . Yes .. this is what I would like to do if you know how.
Thanks for the reply.
Regards
warwick
Hong Kong
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
