USG 60 current temperature
Hi everyone!
I have USG 60 with firmware V4.35(AAKY.2). It seems to me firewall is too hot. How can i see current temperature of the device? Temperature doesn't monitor in dashboard or logs (perhaps i didn't notice it). And i couldn't find any right commands to watch it in CLI mode.
thanks!
Go to console, and type the CLI: Router# debug hardware fan-get.
You will see the current temperature of Device.
However, if the device is quite hot, you should place the device in ventilated environment.
Charlie
Device give an error: parse error/command not found. I guess, my usg does not support this command.0
I think you go to the wrong level to type this command.
After you login, you enter this command directly.
No, it doesn't work anyway. There's same error. I have attached screen with error and command list of debug mode. This list is not contain "fan-get".
The CLI: "debug hardware fan-get" only on USG110 and above series can check it. It depends on the hardware platform's design.
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
