Usg 50 3.30(BDS.9) cannot connect using VPN L2TP IPSEC
Hi, I cannot connect anymore using windows 10 or android device on L2TP/IPSEC. If I use Secure extender I can connect with SSL VPN.
If I run connection i still se on windows "connecting". On zywall VPN Monitor show L2TP_VPN_Connection connected but on log I see 2 strange row:
1st:
2nd:
Any suggest to solve this problem?
Thanks Francesco
1st:
error | IPSec | SPI: 0x49d36825 (1238591525) SEQ: 0x1 (1) No rule found, Dropping ESP/NAT-T packet |
notice | Firewall | Match default rule, DROP ACCESS BLOCK |
Thanks Francesco
Hi @ITS
We have fixed similar IPSec issue for legacy model, I will send firmware to you by private message.
sorry, duplicated
@Zyxel_Stanley There's any way to publish all the "latest patched firmwares" for legacy models?
Unfortunately Stanley sent me a dropobox link but I never received a notification, and now link ha expired. I asked to Stanley via PM to send me it again, but nothing at the moment.
Hi @ITS
I have sent a new link to you again. Please have a check your mail box.
I have a zywall 50 router/firewall and I have this error "SPI: 0x49d36825 (1238591525) SEQ: 0x1 (1) No rule found, Dropping ESP/NAT-T"
Please send me the latest firmware update.
Thanks,
Daiana0 -
Thanks a lot,
Daiana0 -
Hello again,
I am trying to upgrade the firmware, but the message "Firmware upload in progress" never finish.
Please help
Daiana0 -
@Daiana
Regarding to this case,
after updated the firmware for a while, did you refresh the browser page? and can I know was the sys LED still blinking?
Do you have console cable to connect device?
- 431 Beta Program
- 2.6K Nebula
- 170 Nebula Ideas
- 6K Security
- 385 USG FLEX H Series
- 294 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 267 Service & License
- 412 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
