SSL VPN IP addresses
Franc
Franc Posts: 27 image  Freshman Member
edited April 2021 in Security
I have two location connected by SSL VPN.
In each location I have an USG 60.
The problem I am having is the overlap of the ip addresses between the two location,
because both LAN networks have the same ip 10.0.0.xxx :
10.0.0.1 of location A is a server
10.0.0.1 of location B is a computer
10.0.0.254 of location A is the USG 60
10.0.0.254 of location B is the USG 60
Any suggestions without changing all IP of one network?
thanks!
    PeterUK Posts: 4,446 image  Guru Member
    Your going to have to change a subnet.
  • Franc
    Dear Peter
    thanks for your reply, but I don’t understand exactly what you mean.
    Should I have to change the subnet mask?
    The subnet I am using is 255.255.255.0
    or should I have to change the penultimate part of IP address? 10.0.1.xx?
    Please can you give me an example?
    best regards
  • Franc
    Thank you very much!!
