SSL VPN IP addresses
I have two location connected by SSL VPN.
In each location I have an USG 60.
The problem I am having is the overlap of the ip addresses between the two location,
because both LAN networks have the same ip 10.0.0.xxx :
10.0.0.1 of location A is a server
10.0.0.1 of location B is a computer
10.0.0.254 of location A is the USG 60
10.0.0.254 of location B is the USG 60
Any suggestions without changing all IP of one network?
thanks!
thanks!
10.0.1.1 of location A is a server
10.0.1.254/255.255.255.0 of location A is the USG 60
10.0.0.254/255.255.255.0 of location B is the USG 60
5
Your going to have to change a subnet.
Dear Peter
thanks for your reply, but I don’t understand exactly what you mean.Should I have to change the subnet mask?The subnet I am using is 255.255.255.0
or should I have to change the penultimate part of IP address? 10.0.1.xx?Please can you give me an example?
best regards0 -
5 -
Thank you very much!!
- 440 Beta Program
- 292 Service & License
- 4.6K FAQ
